DrunkenSoldier
Sep 29, 2015Follower
Cannot connect to network wn3000rp
So i have windows 10 and have no idea if that does something to the wifi extender. I go to wifi manager and try to connect to (name)_EXT. I stare at the wifi extender and the LED for connecting from ...
hopplaschorsch
Oct 16, 2015Aspirant
Hi
I have the same problem. Why should the operating system have to do anything at all with the wifi extender?
Netgear gives a list of Windows 10 supported products:
Unfortunately, the WN3000RP is not on it.
