lorilone1's avatar
lorilone1
cannot connect to wifi extender ex7300 - can't connect to this network
I had the entire house connected perfectly with 2 wifi extenders and router - all Netgear Products.  Router:  Nighthawk X6 R8000 - Extender  N300 WiFi Range Extender and Extender Nighthawk X4 AC2200 Range Extender.
We recently lost power and I have been unable to get the second wifi extender to cooperate after more than a dozen times of trying everything.  I finally get it hooked up and then final outcome is that I can't connect to this network.  Please help, I have been dealing with this for days now and just need to have this work so I can hook up additional devices.
1 Reply
  • Hi lorilone1,
                          Did you tried turning off all the devices and turn them on in sequence like Router, extender 1 and extender 2. How are your extenders connected to router, ie: both are connected to router or its like router->extender 1->extender 2?
