J2Bs
Feb 22, 2018Aspirant
Cannot connect to wifi range extender
I have set up the wifi range extender, initially very close in same toom as the router. Everything lit up green. I then moved it to the floor between the router and laptop I need the range extending...
jvasanth1984
Feb 22, 2018Virtuoso
Hi J2Bs,
Try to reconfigure the extender by placing it next to router, connect devices and confirm internet access before you move extender to middle floor. Also, check for firmware upgrade for your extender before you move it.
J2Bs
Thanks. I moved it right next to the router, but the same issue occured.
I have registered the product but how do it check the firmware?
- jvasanth1984Feb 22, 2018Virtuoso
Hi J2Bs,
Please follow the below link to upgrade firmware. Inorder to login to extender, ensure your device is connected wireless to extender's network and try mywifiext.net or the current IP address of your extender.
- J2BsFeb 22, 2018Aspirant
If I try this I just get this message "You are not connected to your extender's WiFi network" so I can;t seem to go any further.
Hi J2Bs,
Are you trying to access it from a device which is connected to the extender? What if you try IP address of extender instead of mywifiext.net?
