TonyMan's avatar
TonyMan
Cannot Connect to Xfinity Router
I used to use this with a Netgear router. I switched to the X-1 platform and got a new Xfinity (Cisco) router, DPC3939. Today I tried using the extender for my grandson to connect via Ethernet to his...
  • TonyMan's avatar
    TonyMan
    May 04, 2016
    Thanks for the advice. Believe it or not, I got it to work. I fired up my laptop, plugged it in, and the browser opened to the setup page. Only screw up was when I applied the settings, after about 10 seconds I got a page saying the website could not be reached. The lights showed connectivity, so took it down to the Den, connected it to the Xbox & everything is working now. Only issue left to troubleshoot is why I cannot reach http://mywifiext.net. I can't think of anything I'd want to change, but it's just strange I cannot reach the extender. I also tried going to to it's new ip address, but that did not work either. It's working and that is all that matters right now, I;ll check the access issue out some other time.
    Thanks again for the advice. If it stops working again I will try that.
