LarryStein
Feb 26, 2017Aspirant
Cannot Connect via Wifi to N300 Router
I had done setup 3 months ago and the device was working well. Then last week, I was not able to connect from my MacBook to the range extender. I turned it off/on - no change. I unplugged -- no chan...
DarrenM
Feb 28, 2017Sr. NETGEAR Moderator
Hello LarryStein
Do you have your extenders SSID set with the same name as the main router? if so you may need to have separate SSID.
DarrenM
- LarrySteinFeb 28, 2017Aspirant
It is a different SSID. This was the case during installation -- and is still the case.
- DarrenMMar 03, 2017Sr. NETGEAR Moderator
Have you updated the extender to the latest firmware?
DarrenM
- LarrySteinMar 04, 2017Aspirant
Darren - Thanks. I have not updated the firmware. The device was purchased 2 months ago and was working fine. I have not updated the software of any the devices connecting to it (iPhone and MacBook) -- so not sure what would have changed.
The online suggestions were to reset the device to factory default - which I did.
Is there a reason to believe why a firmware update would help? And if I can't connect to the device - not sure how I would accomplish this.
Appreciate the response.
