Wallace19xx
Jul 27, 2015Follower
Cannot connect WN3000RPv3 to Netgear AC1750 R6300v2 router
I never got the Router Link LED to show any color after I successfully setup the new _EXT network. Do I need to worry about Microsoft's firewall manager?
nhann
Jul 30, 2015NETGEAR Employee Retired
Hi Wallace19xx,
When finishing the new setup for the _EXT network, did you reach a success page? http://www.netgear.com/success/wn3000rpv3.aspx?sn=3Y11485P00093
Is your R6300v2 running the latest firmware? http://support.netgear.com/product/R6300v2
Please also try a factory reset for the WN3000RPv3.
Hi Kinson2339,
Can you please provide more details on the error that you are receiving? Is this error showing when you access the webpage to setup the WN3000RPv3?
I look forward to hearing from you.
NhanN
