smithassoc1
Feb 22, 2019Aspirant
CANNOT LOG INTO ex6100 extender
Hi,Can somebody PLEASE Help
I received a email from Netgear about a update for Ex6100
a Couple of Problems,I had this Extender sey up prior to the NBN & when it went on,it changed the IP address ...
- Mar 24, 2019
After getting help from a service organisation from experts from India yesterday,they came into my Computer & went into my Netgear Genie
& opened the Ip Address of my Extender & once it opened,(very Slow) I logged in under my email address & the Password was password which enabled me to log in & update the Extender & make any Changes within the Extender(like changing the Email address(if you have others) & also to Change the password to what every you want
I hope that Helps
Darryl
smithassoc1
Feb 27, 2019Aspirant
Hi Christain,
when I log into www.mywifiext.net
It comes up with what you expect & I feed all the information required & next & then it throws back to the start again
I have tried approx 10 times & each time it does exactly the same
If I scan my IP addresses,Ex6100 is listed
smithassoc1
Hi Christain,I just tied to access www.mywifiext.net & this time it comes up with that you are not connected to your Extender's WIFI Network
Thanks
Darryl.Smith.
