Rwell
May 14, 2017Aspirant
Cannot login to account www.mywifiext.net
I just bought an EX6120|AC1200 Dual Band WiFi Range Extender. I registered the product and created an account on netgear.nl website. However, I cannot install the product. When visiting http://mywifi...
- May 16, 2017
Hello Rwell
If it is not working I would suggest factory resetting the extender by holding the reset button for 10 seconds then try the setup again.
DarrenM
DarrenM
May 16, 2017Sr. NETGEAR Moderator
Hello Rwell
DarrenM
- RwellMay 17, 2017Aspirant
Dear mr. DarrenM,
Did that and it worked for me. Thanks. Also had contact with Netgear by using the online chat. Good customer support.
