Rwell's avatar
Rwell
Cannot login to account www.mywifiext.net
I just bought an EX6120|AC1200 Dual Band WiFi Range Extender. I registered the product and created an account on netgear.nl website. However, I cannot install the product. When visiting http://mywifi...
  • DarrenM's avatar
    May 16, 2017
    Hello Rwell
    If it is not working I would suggest factory resetting the extender by holding the reset button for 10 seconds then try the setup again.
    DarrenM
