goldstar
Mar 10, 2015Novice
Cannot Open 192.168.l.l
Cannot Open 192.168.I.I Hello, I have BSNL boadband, whenever I try to connect 192.168.I.I it shows explorer cant connect. I bridge connection, I want it to be direct. Thank you :confused::c...
Sleepy_Joe
Apr 14, 2015Novice
Make sure that your computer's IP Address is in that range or else, you won't be able to open it. Try to ping that IP Address too. If you're getting replies, then you should be able to open it.
