Armval's avatar
Armval
Follower
Mar 19, 2014
cannot open https website?
Hi
My PC cannot open sites that starts with https when the PC is connected to the extender with wire. Doesn't matter which 3 browser i use.
When that happen, I always had to reboot the extender. That gets very annoying.
My extender is connected through the netgear nighthawk router wirelessly.
Os there a way to fix it without having to reboot every single time?
  • Did you get a resolution on this?
    I have a service ticket open for an issue that is somewhat the same. I have two EX6200's, one that has a PS3 hardwired to it. If I reboot the EX, the PS3 can sign in to the Playstation Network fine, but if I turn off the PS3 for longer than 6 hours and turn it back on again, the EX won't allow the sign in...unless I reboot. The PS3 works fine if I connect directly to my router by hard wire or if I use the PS3 wireless.
    My other EX has an HTPC attached, and if I reboot, everything works fine. If the HTPC goes to sleep, after 6 hours or so, it won't connect to certain websites (Netflix, YouTube....)
    The EX's DO allow me to access my media server on my LAN even when these problems exist.
  • Lanaber,
    I still have an open support ticket with NETGEAR support. I have been able to document the issue as it occurs every 2 - 3 days and only with secured website (https). I have sent several packet captures to show how the traffic is being stopped. I have take my PCs, bypass the EX6200 and connected directly to the router to verify that I can connect when the traffic is dropped by the EX6200.
    Are the websites that you connect to secured? Can you connect a computer to one of the EX6200 to see if you can access these websites, banking websites when the issue occurs?
  • jmyaz,
    I have my laptop set up through the EX now. As soon as it happens I will see which websites are affected. PSN is one of those affected, and it blocks my Netflix, but I will try the https to make sure.
  • Doesn't seem to happen with my laptop, as I don't set it to sleep...It does happen with my HTPC that does sleep after 4 hours, blocking various https and streaming sites when it wakes up!
  • While working with NETGEAR support I found the issue to be with the wired connection and not the wireless. I was able to reproduce the issue by connecting a laptop to the wireless EXT network, verify I can reach HTTPS website, then plug in a wired connect to the EX6200, disable wireless and verified I could no longer reach the same HTTPS websites. I repeated this process several times to verify.
  • That makes sense as to what I am seeing too. My laptop connected via wireless has no problems, same with the PS3.
    The wired connection is blocking something.
    I sent my config file to Netgear to replicate my problem.
    Now we wait....
  • I have EX6200 connected to the R7000 and I did not encounter this problem. I disable the wireless adapter and connect wired to the EX6200 and HTTPS access works fine.
  • I worked with NETGEAR support and they were able to reproduce the issue. They sent be a beta firmware which I applied and with the unit being up over 20 days without any issues, I believe it has resolved my issue. I am not sure when the new firmware update will be released for GA. It took awhile to resolve but I am happy it has been finally fixed. :)
  • @ jmyaz - Glad it is working on your end.
    For others who have the same issue contact NETGEAR support to get the beta firmware as well.
