bobzam's avatar
bobzam
Follower
Feb 16, 2019
Cannot reset
My old extender has worked fine, but upgraded my widi to Frontier with ARRIS router.  I have tried several avenues to connect this extender but seems I cannot reset. Have held the paper clip in hole ...
  • Christian_R's avatar
    Feb 21, 2019
    Hi bobzam - After resetting your extender, please locate and join the "NETGEAR_EXT" wifi network using a laptop or wireless device. Then browse to www.mywifiext.net and follow the setup instructions.
    ~Christian
