jscibelli49's avatar
jscibelli49
Cannot upgrade firmware WN3000RPV3
I am trying to apply a firmware upgrade to the extender. When I try to connect to login using mywifiext.net I am getting a New Extender Setup screen. No option to login to the extender (I have upgraded the firmware in the past without a problem).
Thank You
  • Hi. I am having trouble logging in to my net gear for wifi to I pad
    can you help. Net gear is logged in to router ok
    • jvasanth1984's avatar
      jvasanth1984
      Virtuoso
      Hi spokes467,
                                 Try mywifiext.net when your device is connected to extender's wifi network. If it doesn't work, try to use the IP address of extender to login which you can retreive from attached devices of your router.
  • Hi jscibelli49,
                             Since you upgrade the firmware, it gets a new interface. Choose new extender setup and create account.
