highstream
Feb 21, 2016Aspirant
Can't access E6200
Yesteday I set up an EX6200 as an extender (or bridge) to a TP-Link AC1700 router via the WPS buttons for 2.4 and 5 GHz, then positioned the the unit where I want it. It shows on my Win 7 x64 laptop ...
DarrenM
Feb 25, 2016Sr. NETGEAR Moderator
Hello highstream
are you able to connect to it via ethernet?
DarrenM
highstream
Feb 25, 2016Aspirant
Do you mean running an ethernet cable from the router to the EX6200?
- DarrenMFeb 25, 2016Sr. NETGEAR Moderator
I mean can you plug a pc into the EX6200 so you are able to get into the settings with mywifiext.com
DarrenM
- highstreamFeb 25, 2016Aspirant
My desktop PC with one ethernet port runs on a cable connection, so how would I connect to the Netgear? My laptop doesn't have an ethernet port.
- DarrenMFeb 26, 2016Sr. NETGEAR Moderator
Highstream
You may have to factory reset the extender and connect to it again via wireless on your laptop and go threw the setup again instead of connecting it with WPS.
DarrenM
