mobiz45
Mar 26, 2017Aspirant
Can't access mywifiext.com after setup
I have tried several times now. I can factory reset the router, access mywifiext.com no problem. It takes me through the setup fine. However, once everything is setup I can't get back to mywifiext....
DarrenM
Mar 31, 2017Sr. NETGEAR Moderator
Have you guys tried to access the extender using its IP address you typically can find it in the attached devices of the router.
DarrenM
mobiz45
Mar 31, 2017Aspirant
I have tried with the default IP as well from the same article that dbanjo referenced. I will check this evening if the IP is different based on what is connected to my router.
