mobiz45
Mar 26, 2017Aspirant
Can't access mywifiext.com after setup
I have tried several times now. I can factory reset the router, access mywifiext.com no problem. It takes me through the setup fine. However, once everything is setup I can't get back to mywifiext....
DarrenM
Mar 31, 2017Sr. NETGEAR Moderator
Have you guys tried to access the extender using its IP address you typically can find it in the attached devices of the router.
DarrenM
dbanjo0335
Mar 31, 2017Aspirant
Also, I have turned off firewall/antivirus, factory reset router and extender multiple times.
- mobiz45Apr 01, 2017Aspirant
No luck for me either. In doing this, I did discover that my modem/router that the extender connects through is now using IPv6. Would this have anything to do with it? I tried putting in the IPv6 address and still nothing. The internet works through the extender, I would like to get into the configuration of the extender and can't succesfully do that after going through the setup.
Well, right after posting this, I tried connect to mywifiext.net from my iPad and was able to get right in! Not sure what the difference is between using computer vs. iPad? I wish I could give you better info dbanjo, other than try a different device.
- jbullockJul 05, 2017Aspirant
Thank you! for sharing this. After I read your post I connected to mywifiext.net using my iPhone and got right in. So I tried my MacBook and got in immediately. I wish I had read your post before I spent two hours trying to change the router password....
