basysaz
Feb 04, 2015Tutor
Can't change WiFi channels on EX6100
I'm in a long single-story house with a Nighthawk R7000 router in the middle and WN3500RP and EX6100 range extenders at both ends, all on Channel 6 (2.4GHz) and Channel 153 (5GHz). After insuring the...
basysaz
Feb 12, 2015Tutor
Thanks for the logical explanation. I'm sticking with the extender configuration but may change the base 2.4GHz channel on the router to avoid other networks in the neighborhood -- and for them to avoid mine! No 5GHz networks reported by various monitoring tools.
I presume both my extenders (EX6100 and WN3500RP) will automatically find and use whatever channel I change to.
BTW, the EX6100 is working great. Anyone need a used WN3000RP?
