nickomaan
Mar 20, 2017Aspirant
Cant change wifi speed on Range Extender N300 from 145mbps to 300mbps?
The main wifi-router and the wifi-modem are both on the living room, next too each other and they are 10-15 meters from the wifi-extender. My room which contains a PS4, laptop and an iPhone 6, are 3-...
- Mar 24, 2017
Hello nickomaan
The extender being on 145MBPs shouldn't matter because you are using your internet speed. Have you tried to adjust the wireless channel on your main router?
DarrenM
nickomaan
Mar 31, 2017Aspirant
LOL i disabled 5GHz on my main router and my extender changed its wifi speed to 300mbps....? Problem solved then! :D
