nathangdavidson's avatar
Aug 26, 2018
Can't connect Chromecast to Netgear Extender EX2700, is it possible?
Hi,
Can I just check that there's no way to configure the settings in my Netgear EX2700 Extender to allow to use it to connect to my Chromecast?
These articles suggest that is the case - as it's not designed to be an Access Point, but I just wanted to get confirmation if possible.
https://community.netgear.com/t5/Cable-Modems-Routers/Chromecast-and-AP-Isolation-Setting/td-p/1149056
https://kb.netgear.com/25226/EX2700-FAQs
Connecting to my router directly is not an option sadly.
thanks
Nathan
  • StephenB's avatar
    Note that the problem in that post isn't about AP mode.  It's about network isolation - a security setting in some wifi devices that prevents wifi clients from connecting to each other.  The EX2700 doesn't do that, even if it is in AP mode.
    Are your chromecast control device (phone or whatever) and the chromecast itself both connected to the same band on the extender?  Try connecting the control device to the 2.4 ghz network.
    • nathangdavidson's avatar
      nathangdavidson
      Thanks for your reply.
      Yes the Chromecast and the device (my tablet) are both connected to the extender.
      When you say try connecting my device to the 2.4ghz network, do you mean try connecting it to the main router? It says the signal is likely to be bad, which is why we've got the extender.
      Am I misunderstainding you?
      • StephenB's avatar
        No, it was my mistake.  The EX2700 is a single-band extender, and only has 2.4 ghz.  I was thinking of a dual-band model that have both 2.4 ghz and 5 ghz extender networks.  So that suggestion doesn't apply to you.
        When you connect the tablet to the extender network, are you able to reach the internet?
  • I read the thread down to the third separate random solution, so going to try doing them all at the same, light the blue touch paper and run
