nathangdavidson
Aug 26, 2018Aspirant
Can't connect Chromecast to Netgear Extender EX2700, is it possible?
Hi,
Can I just check that there's no way to configure the settings in my Netgear EX2700 Extender to allow to use it to connect to my Chromecast? These articles suggest that is the case - as it's n...
Aug 27, 2018Guru - Experienced User
nathangdavidson wrote:
When you say try connecting my device to the 2.4ghz network, do you mean try connecting it to the main router? It says the signal is likely to be bad, which is why we've got the extender.
Am I misunderstainding you?
No, it was my mistake. The EX2700 is a single-band extender, and only has 2.4 ghz. I was thinking of a dual-band model that have both 2.4 ghz and 5 ghz extender networks. So that suggestion doesn't apply to you.
When you connect the tablet to the extender network, are you able to reach the internet?
nathangdavidson
Aug 27, 2018Aspirant
Ok.
When you say 'When you connect the tablet to the extender network, are you able to reach the internet?'
Are you asking if I can use the internet on the tablet when I connect to the extender, rather than the main router?
If that's what you're asking, the answer is, yes I can. It works fine.
- StephenBAug 28, 2018Guru - Experienced User
Yes, that is what I was asking. The Chromecast also connects to the internet for some things, so I wanted to confirm that wasn't the issue.
It should be working, I don't have any other troubleshooting ideas at the moment. Hopefully other posters will chime in.
- nathangdavidsonAug 30, 2018Aspirant
Hi, I just wanted to update that I used a different device - i.e. my phone not my tablet - and connected successfully this morning. I have no idea why this different device worked, but I'll take that for now.
Best,
N
- staten7Aug 30, 2018Aspirant
I'm having the same problem. The extender is enabling connections to my laptop, my phone and my Chromecast but as noted in the article at the top of this chain, I can't seem to change the AP security setting in the extender so that the phone can be used to tell Chromecast what content to show. Basically the Chromecast is worthless in this configuration. If I can't get this resolved I'm going to have to return the EX2700.
Please help me solve this problem.
