nathangdavidson
Aug 26, 2018Aspirant
Can't connect Chromecast to Netgear Extender EX2700, is it possible?
Hi,
Can I just check that there's no way to configure the settings in my Netgear EX2700 Extender to allow to use it to connect to my Chromecast? These articles suggest that is the case - as it's n...
Aug 28, 2018Guru - Experienced User
nathangdavidson wrote:
If that's what you're asking, the answer is, yes I can. It works fine.
Yes, that is what I was asking. The Chromecast also connects to the internet for some things, so I wanted to confirm that wasn't the issue.
It should be working, I don't have any other troubleshooting ideas at the moment. Hopefully other posters will chime in.
nathangdavidson
Aug 30, 2018Aspirant
Hi, I just wanted to update that I used a different device - i.e. my phone not my tablet - and connected successfully this morning. I have no idea why this different device worked, but I'll take that for now.
Best,
N
