c-c-m
Nov 22, 2016Aspirant
Can't connect to a network from Android or Linux, but I can on Windows
I have configured my Wifi Range Extender and has been working flawlessly for months. However I have noticed that when I turned my two computers using Linux (kubuntu 16.04) on, they could not connect ...
DarrenM
Nov 29, 2016Sr. NETGEAR Moderator
Hello c-c-m
Do you have the extenders SSID named the same as your main router if so you may want to change the SSID.
DarrenM
c-c-m
Dec 04, 2016Aspirant
Thank you, but it was solved as espontaneously as it appeared. I am assuming it might be a problem with drivers or kernel (I could connect using a wired connection and update Kubuntu)
