Pedowski
Nov 27, 2018Aspirant
Cant connect to extender (AC1900)
It has worked before, but now i cant connect any device to any of the extended-wifies, everything is green. Will only work if i put ethernet cable from router in to it, but i need it for extending my...
- Nov 27, 2018
Pedowski wrote:
Can connect to myeifiext.net but i cant use internet. Hardware is : Ex7000 and Firmware version is: V1.0.1.78_1.0.140
Thx. Lots of folks here have had trouble with that firmware. I suggest that you try downgrading to 1.0.0.66. Then do another reset, and see if that solves it. https://kb.netgear.com/000059563/EX7000-Firmware-Version-1-0-0-66
Nov 27, 2018Guru - Experienced User
Did you try resetting the extender and setting it up again?
