andynnnn's avatar
andynnnn
Follower
Oct 22, 2013
Can't connect to internet -- how do I change IP address
Switched to a new Linksys router -- maximum address of 192.168.1.149 -- can't find range extenders WN2000RPTv2 or WN3000RP -- I think I need to change the IP address -- how do I do that from a PC?
1 Reply
  • What is it you're asking us to help you with - change the address of what?
    If you have changed the router you most likely need to reset the range extenders and reconfigure them so they will connect to the new router.
