erikdiamond
Aug 10, 2016Follower
Can't connect to Internet every time computer wakes up or boots up.
I set my wifi Range extender with my computer running Window 10. Everything worked fine. But when I turn on the computer or when computer wakes up from sleep, it states that DNS is not found nor that I am not connected to Internet. I had to keep rebooting extender in order to work again. I do not want to do that every time. So how to fix it so that computer will have access to internet without having to reboot extender.
Thanks,
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello erickdiamond
You may want to try and do a address reservation for that pc on your main router that might fix the issue. Also make sure you have the latest drivers for your pc wireless card for windows 10.
DarrenM
