beabutler
Dec 22, 2016Follower
Can't connect to my extender
Hi, I've boutght a range extender WN3000RPv3 a few months ago. With some difficoulties I have installed it but it worked only a day. Yesterday i tried again with it and as I turnen it on it worked, b...
jaksnipe
Jun 11, 2017Aspirant
Had this same problem. I disconnected my WAP from router, connected to it over WiFi, then manually changed my IP address to one in same subnet (192.168.0.200). Then, I could connect to the admin console. I suspect this will work for the extenders as well. First thing I did once I got into the admin console was check for updates and there was a firmware update available that's supposed to fix this problem. So... if you can get to the WAP, there's an update that fixes the problem of not being able to get to the WAP. :\
