Sander92
Jun 28, 2015Tutor
Can't Connect to my N300 Range Extender
Hi guys, I purchased an N300 EX2700 WiFi Range Extender yesterday, plugged it all in, did the set up and everything was fine, everything connected. I went out today then came back and noticed I wa...
Babylon5
Jun 29, 2015NETGEAR Employee Retired
If you log into the extender does it show a good connection to the base router? What manufacturer and model number is the base router? Are you using a Wireless Access List at all?
