Sander92
Jun 28, 2015Tutor
Can't Connect to my N300 Range Extender
Hi guys, I purchased an N300 EX2700 WiFi Range Extender yesterday, plugged it all in, did the set up and everything was fine, everything connected. I went out today then came back and noticed I wa...
Sander92
Jul 01, 2015Tutor
Babylon5 wrote: If you log into the extender does it show a good connection to the base router? What manufacturer and model number is the base router? Are you using a Wireless Access List at all?
When you say log in, do you mean through mywifiext? If so it won't let me log in. Keeps saying "oops looks like you've been redirected".
The base router is a BT home hub 4. And I'm not sure what a wireless access list is sorry.
