Sander92
Jun 28, 2015Tutor
Can't Connect to my N300 Range Extender
Hi guys, I purchased an N300 EX2700 WiFi Range Extender yesterday, plugged it all in, did the set up and everything was fine, everything connected. I went out today then came back and noticed I wa...
Babylon5
Jul 03, 2015NETGEAR Employee Retired
The 'oops' message usually means that you are not actually connected wirelessly to the extender, but instead you are connected to the router. Can you connect to it with an Ethernet cable?
