Sander92
Jun 28, 2015Tutor
Can't Connect to my N300 Range Extender
Hi guys, I purchased an N300 EX2700 WiFi Range Extender yesterday, plugged it all in, did the set up and everything was fine, everything connected. I went out today then came back and noticed I wa...
Sartis
Oct 27, 2015Aspirant
I have a similar problem.
I've set the extender up according to instructions and all lights are green.
With the extender in the same room as the router, I can't link to the extender by wifi.
The extender name pops up on my list of wifi options but won't link with iphone or ipads. It just keeps trying to link continuously but never gets there.
Is the extender faulty?
Alan
nhann
Oct 27, 2015NETGEAR Employee Retired
Hi Sartis,
Are you also using the EX2700 Range Extender?
Which router are you using with it?
Is the extender plugged into the wall and connected to the router via an ethernet cord? or is the extender just plugged into the wall with no ethernet cord connection?
Have you completed the setup procedure via WPS or web browser?
See page 5 of 20:
http://www.downloads.netgear.com/files/GDC/EX2700/EX2700_QSG_booklet_30July2015.pdf
Try resetting your Range Extender back to factory defaults and complete the steps mentioned above.
This process erases any settings that you configured in the extender.
- Insert a paper clip into theFactory Resethole and hold it until the Power LED blinksamber.
- Release the button.
- All the LEDs turn off for about 3 seconds.
- The Power LED lights solid amber for about 30 seconds.
- The Power LED lights solid green.
- The extender returns to its factory settings
