Liddle
Jan 16, 2018Aspirant
Can't find Netgear Extender EX6100 wifi network
Neither my Apple notebook nor my IPhone can see my Netgear EX6100 network; so i can't set it up. I tried the hard reset on the Netgear, moving it, unplugging it, etc. Should I try a buying a differ...
- Jan 18, 2018
Hi Liddle,
Check if you can connect a Desktop or Laptop wired to it and gain access to its setup screen.
jvasanth1984
Jan 17, 2018Virtuoso
Hi Liddle,
I would like to know if you perform reset when device is powered on. Please follow below link on how to reset the extender.
https://kb.netgear.com/26082/How-to-reset-my-EX7000-to-factory-default-settings
- LiddleJan 18, 2018Aspirant
Yes, multiple times it was reset. I also moved the location of my notebook and extender. Also tried two different browsers, Chrome and Safari. And reset my computer.
- jvasanth1984Jan 18, 2018Virtuoso
Hi Liddle,
- LiddleJan 24, 2018Aspirant
Your suggestion was good. When I hard-wired my computer to the EX6100 it did exstablish a connection. But I was never able to get it to connect to my network using WiFi. I bought another unit, and it worked right away. So I guess the old unit was bad. Thank you , for your help.
