Liddle's avatar
Liddle
Can't find Netgear Extender EX6100 wifi network
Neither my Apple notebook nor my IPhone can see my Netgear EX6100 network; so i can't set it up.  I tried the hard reset on the Netgear, moving it, unplugging it, etc.  Should I try a buying a differ...
  • jvasanth1984's avatar
    jvasanth1984
    Jan 18, 2018
    Hi Liddle,
                   Check if you can connect a Desktop or Laptop wired to it and gain access to its setup screen.
