bote110
Nov 16, 2014Tutor
Can't get 2.4g back
So I had my AC1200 set to have the 2.4 and 5g operate at the same time on channel 11and wanted to see if I can set the 5g to the AC1200 and to the modem at 2.4g {fast Lane setting} my apple tablet can...
Mars Mug
Nov 16, 2014Virtuoso
If the 2.4GHz band is being used to communicate with the Arris, then that would normally be unavailable for client use. You should be able to access the ‘6200 using the 5GHz band at the usual admin URL, otherwise you could just factory reset the ‘6200 and run through the setup again (or reload from a backup).
