dmilinevskyi
Mar 21, 2018Aspirant
Can't get ip address
My problem is very similar to another issue when a client can't reconnect to the network I don't consider static ip assignment is a solution. I have to reboot the repeater a couple of times a da...
jvasanth1984
Mar 22, 2018Virtuoso
Hi dmilinevskyi,
This may occur if your extender is not getting better connection from your router. Since your extender is connected only to 5GHz of your router, please change 5GHz channel on router to see if that resolve your issue.
- dmilinevskyiMar 23, 2018Aspirant
Thanks jvasanth1984
Good point!
Previously I've been using automatic channel selection on the router side but it caused problems as repeater didn't catch up if router decided to swap the channel.
So I've hardcoded it to 36. I've changed it to 52. Unfortunatelly I can't change the channel on the extender (I don't really understand why this options is not available).
I'll post an update after I finish my experiments (a couple of days to ensure that the "fix" is stable).
- jvasanth1984Mar 23, 2018Virtuoso
Hi dmilinevskyi,
Extender will not have its individual channel since it is extending router's signal because of which you'll not have an option on extender to modify wireless channel on extender.
- dmilinevskyiMar 29, 2018Aspirant
Hi,
it didn't help to have different channels.
When I disallowed devices to attach to both APs (to avoid handover) the issue seems to disappear.
BTW I don't understand why repeater can't have a different channel.
Obviously it does more than just ampliphying the signal (it changes the SSID for instance).
I don't know the internals of the implementation but from my point of view there's a SW/HW L1 bridge between the repeater's wifi Client and AP.
And that's likely causing the issue.
- dmilinevskyiApr 02, 2018Aspirant
So even with such isolation (avoiding wifi handover between the AP and the Externder) didn't help.
The devices can't get IP address or already connected devices don't have internet access.
Only extender reboot helps.
What else could be done to diagnose this?
Thank you!
