Caesar1948
Oct 04, 2018Aspirant
Can't log into extender after firmware upgrade
I use my extender with a MacBook Pro that runs MACOS Mojave.
I got the email about a firmware update, so I went to work. The installation seemed to go well, and the extender is working just fi...
- Oct 16, 2018
Hi Caesar1948,
Welcome to the community!
It is recommended to do a factory reset after a firmware update. Please keep us posted if you have done a reset and if the issue will persist.
Dexter
Community Team
DexterJB
Oct 16, 2018NETGEAR Moderator
Hi Caesar1948,
Dexter
Community Team
DexterJB
Oct 22, 2018NETGEAR Moderator
Hi Caesar1948,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
