Caesar1948's avatar
Caesar1948
Can't log into extender after firmware upgrade
I use my extender with a MacBook Pro that runs MACOS Mojave.    I got the email about a firmware update, so I went to work. The installation seemed to go well, and the extender is working just fi...
  • DexterJB's avatar
    Oct 16, 2018
    Hi Caesar1948,
    Welcome to the community!
    It is recommended to do a factory reset after a firmware update. Please keep us posted if you have done a reset and if the issue will persist.
    Dexter
    Community Team
