Olebull
Oct 19, 2015Aspirant
Cant log on to my WN3000RPv3
I just bought a N300 wifi extender, WN3000RPv3. I pyshed the wps button on the router and have a connection. Using my samsung tablet, I find the new _ext network but i can not log in using the wirele...
nhann
Oct 20, 2015NETGEAR Employee Retired
Hi Olebull,
Please factory reset the WN3000RPv3:
Insert a paper clip into the Factory Reset hole and hold it until the Power LED blinks amber
Release the button.
All the LEDs turn off for about three seconds.
The Power LED lights solid amber for about 30 seconds.
The Power LED lights solid green.
The extender returns to its factory settings
Then "Connect with NETGEAR genie Smart Setup" (page 11 of 43)
http://www.downloads.netgear.com/files/GDC/WN3000RPV3/WN3000RPv3_UM_2Sep2014.pdf
username: admin
password: password
- OlebullOct 27, 2015Aspirant
Thank you. This solved my problem.
At my first effort i could connect with a lan-cable but not wireless. Now it works wireless as well.
