dgb25
Sep 24, 2018Aspirant
Can't login to N300/EX2700
I am attempting to setup my N300/EX 2700 Wifi Range Extender. I join the NETGEAR_EXT and then I create a username and password along with the 2 security questions. Save it and then I am prompted to...
dgb25
Sep 25, 2018Aspirant
Did another factory reset and then recreated user id and password as simple as possible and still won't work. Sending it back. Terrible user experience.
MarcoBo
Sep 26, 2018Tutor
I am experiencing the same exact issue. I tried connecting to www.mywifiext.net and I receive an error message saying that I am not connected to the extender network (I was). I tried following the links given in the error page and they can't be reached. i tried registering the product and creating a MyNetgear profile but the My support page won't load on any browser. I am supposed to be able to access the live chat but I am ping-ponged between the same site pages that keep asking me to login without providing any real contact links. I posted a question in the community but it has now disappeared and the web site keeps switching from my own language to English any time I load a new page. Seriously annoyed by the utterly poor quality of the service. Can somebody please help set up these extenders?
- MarcoBoSep 26, 2018Tutor
dgb25 I might have figured it out on my own. If you use a Mac, you can try following my same procedure. After you plug in the extended to a socket, connect your device to the EXT wifi network, then ignore the pop-up window that automatically comes up and try to reach any website from your browser. Instead of your chosen website, you should be redirected to the Netgear loging page. If you enter your credentials here, they should work. If this doesn't solve the issue, I'm afraid I'm clueless. Hope it helps.
