mhinh
Jun 04, 2015Novice
Cell Phone Hot Spot as Part of my Nighthawk Network
My download capacity is limited to 17Gb per month (rooftop dish for internet access with exeed). I have 10Gb available on our cell phone accounts. When we run out of exeed capacity we use our smart p...
Fairytail
Jun 04, 2015Virtuoso
In order of your devices to be able to communicate to each other you should be connected on the same network. If your Phone is using the data network that means it will be disconnected from the routers network which results to your phone not being able to see other devices.
