Jansimms51's avatar
Jansimms51
Follower
May 30, 2022
Centurylink C4000BZ
I have this dsl router from Centurylink. I would like to connect the Netgear wifi range extender to it. How do i do this and make it work.
1 Reply
  • plemans's avatar
    You should be able to simply install the extender using the installation assistant.
    have you tried that?
    what extender do you have?
    What method of setup are you using?
    Where is it failing in the process?
