gscara
Aug 09, 2018Aspirant
Change Extender MAC address
Hello - I would like to know whether it it possible to change an AC1900 MAC address. I have been using the AC1900 to extend the connection of the router placed in a common area of our building, ...
Aug 10, 2018Guru - Experienced User
Is the extender connecting to the router on 2.4Ghz or 5? What color are the link rate LEDs?
- gscaraAug 10, 2018AspirantThanks for the reply. The Extender connects to 5Ghz. The Ghz leds are off (which I believe is not normal).
- StephenBAug 11, 2018Guru - Experienced User
gscara wrote:
The Ghz leds are off (which I believe is not normal).I agree. One of the link leds should be lit (indicating that the extender is connecting to the router on that band), ideally green in color.
One thing you could try is a factory reset (setting the extender up again).
- gscaraAug 11, 2018AspirantUnfortunately I tried a couple of hard resets per manual (pressing the reset button for 7seconds etc etc) but the same issue occurs.
