jamiehart
May 03, 2016Follower
Changed password for router and now cannot set up my extender
Hi! I changed the password for my router and since then I have not been able to use my extender. I have gone through the complete set up process again by factory resetting the extender and u...
doraemon
May 06, 2016Prodigy
What password did you changed? Is it the wifi password?
If it is, you will have to reconnect the extender to the signal of the router using now the new password.
You will need to access the administrative page of the extender to connect it.
But best way is to reset the extender and start all over just to be sure that you're not missing any step.
Poke the reset hole while it's still on to return the unit to its factory default.
