m00rE's avatar
m00rE
Changing EX 7000 SSIS paswords
I forgot one the two passowrds for my dual band EX 7000 range extender.  How can I easily reset the PW for the bandI have forgotten the PW?
  • plemans's avatar
    login to the extender through the working ssid (the one you know). Once logged into the extender, you can change ssid's and passwords.
    mywifiext.net
    Or you can log in via a hardwired device. this bypasses needing the ssid password. You just need to know your gui login info
    • m00rE's avatar
      m00rE
      and how do I find my GUI login details?
      • plemans's avatar
        hopefully you remember them.
        The defaults are:
        login: admin
        password: password
        if you changed them and don't remember them, the only way back in is to factory reset it and start back from fresh. To do that, push the reset button (while powered on) for 7-10 seconds, until the lights change.
