DanBobber
Mar 09, 2018Aspirant
Changing IP Address on AC1200 WIFI Extender
WIFI Extender Ex6150AC1200 Has anyone successfully chnaged the IP address of this device from 192.168.1.250? My whole network is set up as 192.168.0.xxx. I have attempted to change the IP address vi...
DanBobber
Mar 10, 2018Aspirant
Per Netgear tech support the default IP address of 192.168.1.250 can not be changed, contrary to what the documentation states. This works if your network is setup to the Netgeaf subnet "standard". Will not work if your network is configured to anything other than 192.168.1.xxx.
jvasanth1984
Mar 10, 2018Virtuoso
Hi DanBobber,
May I know from which article are you getting this information. Extender's default IP(192.168.1.250) can be changed.
- DanBobberMar 10, 2018Aspirant
Well, then somebody needs to tell NetGear tech support. I was on the phone with them for over a hour, up to “second level” and they could not figure it out. Finally, told me I would have to change all the devices to subnet 192.168.1.nnn. No thanks. Returned it.
