Mar17
Nov 03, 2018Aspirant
Client Link LED with Ethernet Cable
Should the client link LED be green when the router extender is connected via ethernet cable to computer devise?
Nov 04, 2018Guru - Experienced User
I'm not sure, the documentation is a bit ambiguous.
It's easy to test though. Try disconnecting all your client devices, confirm that you have connectivity with ethernet, and see if the client LED is lit. It'd be helpful if you could post the result.
Mar17
Nov 04, 2018Aspirant
I did try and with Ethernet unplugged the light was on and when plugged back in it went off. But was able to connect devise via Ethernet so all good
