RonMele
Mar 24, 2016Follower
Client Signal Dropping
My range extender keeps dropping the client signal. The router link LED is steady green and when the client signal is broadcasting it is also steady green. The problem is that the client signal reg...
DarrenM
Apr 01, 2016Sr. NETGEAR Moderator
Hello RonMele
I would make sure you are on the latest firmware also try changing the wireless channel to get a better signal and less interference.
DarrenM
