pacorramos
May 19, 2017Aspirant
Clone same SSID of router network for 2.4Ghz extended network
Hi all, I would like to know if I can clone the same prmary router SSID for my 2.4Ghz extended network (i.e. "Name" instead of "Name_2GEXT"), leaving 5Ghz network, which I don't use at all, as it...
- May 24, 2017
Hello pacorramos
You can do this but not recommended even though it has the same SSID it is still a separate network from your main routers network.
DarrenM
DarrenM
May 24, 2017Sr. NETGEAR Moderator
Hello pacorramos
DarrenM
- pacorramosMay 25, 2017Aspirant
OK. So I will leave it as it is.
Thank you!
