pacorramos's avatar
pacorramos
Clone same SSID of router network for 2.4Ghz extended network
Hi all,   I would like to know if I can clone the same prmary router SSID for my 2.4Ghz extended network (i.e. "Name" instead of "Name_2GEXT"), leaving 5Ghz network, which I don't use at all, as it...
  • DarrenM's avatar
    May 24, 2017
    Hello pacorramos
    You can do this but not recommended even though it has the same SSID it is still a separate network from your main routers network.
    DarrenM
