jeth's avatar
jeth
command to reset wireless
Is there are any to issue the command to reset the wireless section of the router without going through all of the router menus?
Wireless frequently stops working and I have to either to a power off/on sequence (which interrupts other family members) or log into the router's menus and go through the pages to get to the reset option.
If there is some way to issue this command from the command line, I could make up a simple shortcut that I could click on to perform this function.
    How are the other family members connected? Are you the only wireless user?
  • I don't know what happened just then, but in the middle of trying to reply, I must have hit the wrong key.......
    Otheers may be using wireless and obviously would want unit to be reset.
    However if one is using a wired connection, and in the middle of something, she tends to get upset if I have to use the simpler power off/om approach.
  • Unfortunately you can just restart wireless without power on/off the router
  • "Unfortunately" ? ;)
    Other than powering off/on the router, the only thing I have found so far is the following; if you have something else in mind, I'd appreciate it if you would pass it along.
    Open routerlogin page
    Log in
    Select Router Status
    Select Connection Status
    Select Renew
    Log out
    For those instances where I find just one specific computer cannot get access to the internet, I have two batch files which I can invoke to get things going again. One is simply "ipconfig /release" and the other used to be just "ipconfig /renew". But later I found a more lengthy series of commands on a MS page that is more reliable. Both can be invoked from simple shortcuts.
    The latter, in case any readers are interested consists of the following commands:
    ipconfig /release
    ipconfig /renew
    arp -d
    nbtstat -R
    nbtstat -RR
    ipconfig /flushdns
    ipconfig /registerdns
    pause
    I added the "pause" so I could check for any error messages.
    However, as I mentioned this works for cases where just a single computer has a problem, and not with this wireless problem.
