greggrimm's avatar
greggrimm
Follower
Jan 08, 2017
Configuration for Nighthawk X6 - powerline 1200 - and AC1200
I have a Nighthawk X6 - the wifi coverage is weak upstairs.
I purchased a powerline 1200 and access point ac1200. My plan is to connect the nighthawk x6 to the ac1200 upstairs using the powerline 1200.
Is this a workable solution?
What configuration of the router and access point would you recommend?
Thanks in advance!
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello greggrimm
    This setup should work fine if you have no issues with the power line connection to the upstairs nothing special would need to be done.
    DarrenM
